Fox 2015: Forks I w...
[Closed] Fox 2015: Forks I want don't seem to exist in 650b
[#6549687]
After a set of new forks and fancy some travel adjustment.
Noticed you can get a set of 2015 36 TALAS in 180/140mm travel but it turns out these are 26" only. WTF, I thought 26" was dead?
The 650b model only offers 160/130mm.
Alternatively I could give up the travel adjust and get Floats in 170mm but slightly annoying the 26" line up is better than the 650b.
Anyone know if there will be a 180/140mm in 650b from Fox?
Posted : 12/10/2014 9:12 pm
As far as I know 170mm is the Max in 650b
Posted : 12/10/2014 9:14 pm
That's a shame.
If the 170's had travel adjust that would be perfect but they don't.
Anyone know of any other forks that have min 170mm travel and have travel adjust in 650b?
Posted : 12/10/2014 9:27 pm
You can get 180mm 36's in 650b, they come OEM on a couple of bikes, the cube fritz for example. I remember reading somewhere that all you need to do is take a spacer out of the air spring to bring a 170mm model to 180.
This is for floats though, not sure about the TALAS models.
Posted : 12/10/2014 9:34 pm
Fox tame the trail, whereas 650b makes it come alive. Oxymoron bike would explode....
Posted : 12/10/2014 9:43 pm
If you can pick some of these up they should be ok?
http://www.xfusionshox.com/product/previous-models/2014-shocks/2013-vengeance-hlr-dla.html#specifications
Posted : 12/10/2014 9:46 pm
26 is going to be around for ages, smaller wheels are still easier for designers to package in long travel frames.
If I was looking for something in the 160-180mm travel range I wouldn't mind 26inch wheels.
I think bigger wheels come into their own on hardtails and shorter travel bikes.
Posted : 12/10/2014 10:13 pm
