is it just a case of re tightening it?
Posted : 07/12/2011 5:15 pm
Check the rim for wobble first.
If so, it may be down to the loose spoke, so tighten it and repeatedly check agains the rim wobble.
All spokes should have a similar tension/twang.
Experiment slowly, worst you can do is make it a little worse, then have to reverse your operation.
Factory-made wheels often need tightening after a short while.
PaulD
Posted : 07/12/2011 5:19 pm
Not pulled out of anywhere or got a dodgy nipple? I'd check the hub flange and the nipple/eyelet?
Posted : 07/12/2011 5:20 pm
