Fortitude 3" t...
[Closed] Fortitude 3" tyres?
[#7501613]
Hi All
I have a Genesis Fortitude ss, fitted with 2.2 mountain kings tyres, do you think it will take a 3" tyre. Std rims and running tubed
3" or 3"+ curious
Posted : 07/12/2015 11:30 am
Not a chance in the back and I doubt it in the front. I had a 2.35" bontrager XR4 on the front of mine and that is as big as I think you'd want to go.
Posted : 07/12/2015 11:41 am
As above.
In the front - yes
In the rear (ooh er) - not a chance
I run a wide rear rim on mine which helps make the most of the modest clearance and can get away with fairly low PSI.
[URL= http://i225.photobucket.com/albums/dd279/letmetalktomark/image.jpg1_zpsdhnssen5.jp g" target="_blank">http://i225.photobucket.com/albums/dd279/letmetalktomark/image.jpg1_zpsdhnssen5.jp g"/> [/IMG][/URL]
Posted : 07/12/2015 11:53 am
Is that the std fork your running
Posted : 07/12/2015 12:05 pm
Knard on hope enduro rim is fine up front. Maxxis chronicle on velocity blunt was rubbing. Rear is a no no.
Posted : 07/12/2015 12:18 pm
Its a Salsa Cromoto - Its 5mm taller than the std Genesis fork.
Its a Knard on a Dually.
there is a fair amount of room all around:
Posted : 07/12/2015 1:35 pm
