Formula rx brakes n...
[Closed] Formula rx brakes need bleeding everytime !
[#4366833]
My lads formula rx's need bleeding everytime we go out on it !,it's the rear only as soon as I've bled them it's fine ,& air does come out you can see it up the tube !,but leave it a week & lever comes back to the bar again.
I'm using syringes pushing fluid from the master cylinder to the caliper,I fill the syringe & it's usually needs two syringes to get a lever !
There dosn't appear to be any fluid loss,or evidence of leaks !,what's up with it ?,or am I doin summert wrong ??.
Posted : 16/09/2012 12:12 pm
Posted : 16/09/2012 12:16 pm
Hang on... are you just bleeding from the bottom? That's not how it's done with Formula, really got to follow the process or it won't work.
Posted : 16/09/2012 12:19 pm
No,I go from master cylinder to the caliper!, what's the technique then ?,talk to mi!. Please...
Posted : 16/09/2012 12:25 pm
Guides on YouTube. Search them for full info.
Posted : 16/09/2012 12:30 pm
Oh ya, sorry, reading and advice failures there from me. You need Big Dave the Giver and his mates
http://singletrackworld.com/forum/topic/bleeding-brakes-how-to-an-idiots-guide?replies=43
Posted : 16/09/2012 12:43 pm
Have you lost the little o ring seals? Mine have been bled once in 2 years
Posted : 16/09/2012 12:53 pm
Edit...kinky no worky...
Soz....
Posted : 16/09/2012 3:49 pm
I have Rx brakes, don't have the issue around bleeding them but do find I get brake 'judder' under heavy braking. It's almost like abs. Would that be the pads being awful?
Posted : 16/09/2012 4:14 pm
