Formula rotors with...
[Closed] Formula rotors with Shimano brakes - any reason why not?
[#8025364]
Want to replace my Formula RX brakes with Shimano. Any reason why I can't keep the 180mm Formula rotors as it seems most new brake sets come without rotors?
Posted : 30/08/2016 1:46 pm
go ahead, been doing it for years
Wrong way round imo! (if you don't squealy brakes!) The formula rotors are nice and lightweight, but ime, that means they really squeal easily)
But other than that, no reason not to keep the formula rotors
Posted : 30/08/2016 6:52 pm
Is it the ones with the 2 rows of round holes? They should fit fine but they're a bit shit, they wear very unevenly so make sure they're in decent nick first.
(the other type formula do, their "standard" rather than "lightweight" rotor, is much better ime. The lightweight one used to be basically XC race only but now they sell it with everything because lightness sells. Kind of a dick move)
Posted : 30/08/2016 7:34 pm
Those are the ones Northwind. May just have a look round at the deals with and without rotors and go from there.
Posted : 30/08/2016 10:30 pm
Had my formula rotors for 2years, 3000km and they are knackered much more so than any other rotors I've ever had. I think they're just a bit rubbish.
Posted : 30/08/2016 10:45 pm
To go against the some of the views above been using formula rotors with saints for the past 18 months with no issues or break squeal when using original shimano pads (superstars squeal like a stuck pig though). Pretty sure they are the lightweight rotors (2 sets of holes on the breaking surface) and 5 years old now, used in the grinding paste mud of the Peak District most weekends and show minimal wear
Posted : 30/08/2016 11:05 pm
Likewise sofa boy!
Posted : 31/08/2016 12:13 am
I had no idea there was a potential issue, picking up a Formula Oro 180mm and a Lightweight 160mm for £10 total at PX, to use with the Wazoo's M355 discs and pads!
Seems to work fine, mainly bought for convenience, so I have a set of rotors fitted on fat and NotFat wheels for a quicker swap out.
Might be coincidence, but it took a fair bit of tweaking to get rid of a bit of disc rub on the front.
Posted : 31/08/2016 1:07 pm
