CRC carry a few bits, but seem mostly out of stock, does anyone know if it is possible to get just the brass/nickel Formula bleed nipple adaptors (top left in the below pic) anywhere? I don't need the full kit. Damn thing broke off in the caliper when I tried to bleed my front caliper the ofther day.
Which means I also need the Oro caliper bolt kit, CRC again out of stock.
Try the distributor Propel Bike. I think Garlands are a dealer too so they could order them for you if need be.
If your desperate I have a Avid bleed kit you could use which is the same fitting IIRC.
Cheers, I've sent propel an email.
UK Bike Store might be worth a call.
Aren't Juicy bleed kits the same (Formula designed the Juicy's for Avid and the bits are all the same size - or something like that a)?
I used the avid kit... worked fine, I think it was cheaper too.
