Formula K18 spares.
[Closed] Formula K18 spares.
[#1679392]
Need to replace the connector at the caliper after an impromptu meeting w/ a tree...
Am i right in thinking that the replacement connector sets look somewhat different than the OEM bits, e.g.:
http://www.chainreactioncycles.com/Models.aspx?ModelID=22472
ta,
stan.
Posted : 07/06/2010 9:20 am
the "machine" fitted end contector is different looking and that is the correct fitting (though usually for shortening the cable at the lever end). You will lose a slight amount hose in fitting that connector.
Posted : 07/06/2010 9:37 am
thanks for that, , klunk.
i'm a hydro noob, but learning quick.
will good cable cutters deal happily with brake hose?
Posted : 07/06/2010 9:40 am
I always use a scalpel and something in the back of my mind is telling me that you shouldn't use cable cutters for some reason or another.
Posted : 07/06/2010 9:45 am
