Formula Hubs - Cart...
[Closed] Formula Hubs - Cartridge Bearing Change
[#2908395]
I've noticed that the rear hub on my hardtail has started to make a little noise.
I stripped it down & determined the non-freehub side bearing is a little notchy, so I think this is the cause.
I can get the freehub side bearing out with no problems, but it looks like I need to remove the freehub body to get to the non-drive side bearing.
I'm not 100% certain which tool I need to get the freehub off.
From having had a look at it it either looks like: -
1. A 12mm or 14mm allen key
2. The Suntour Two Notched system, which requires the Park FR-2 tool to remove (I took a look in the Park Tool repair book to find this out)
I don't own either tool, so I'd like to make sure I buy the right one for the job.
The hubs are from a 2010 bike.
Does anyone have any experience of working with these hubs? If so which tool do I need to get the freehub off.
Thanks
Posted : 02/07/2011 5:11 pm
Anyone have any ideas?
Posted : 04/07/2011 7:36 pm
I think you sound like you'll need a new freehub. The piece you can see in the end that you think you need a Suntour tool for is just a shield. You will need a big hex key, but should be able to get a spare freehub from a DECENT LBS.
Posted : 04/07/2011 8:03 pm
Turned out to be an 11mm allen key in the end & the non-drive side bearing needed replacement - thanks for the advice
Posted : 10/08/2011 10:22 pm
