Formula brake calip...
[Closed] Formula brake caliper o-ring size??
[#5171150]
The little rubber o-ring on my Formula Oro caliper (the one behind the little grub screw) is looking a bit worse for wear when i was bleeding them earlier- anyone know the o-ring dimensions?
Thanks in advance!
Posted : 19/05/2013 7:43 pm
Nope,but got a bag of them in my toolbox in work. Bl***y expensive too, at £1 a go.
Posted : 19/05/2013 8:50 pm
winstanley's do them for oros: [url= http://www.winstanleysbikes.co.uk/product/44261/Formula_Bleed_Port_O_Ring ]clicky clicky[/url]
Posted : 19/05/2013 8:56 pm
Wishing i'd measured the thing before I put it back in now, but it was a bit crushed.
I think they are 2mm ID, 1 mm thickness from a bit of internet trawling. In which case, they are about £8.56 for 100 from these guys [url= http://simplybearings.co.uk/shop/Seals-O+Ring+Seals-VITON+O-Rings/c19_4501_4706/index.html ]click[/url]
I was hoping someone would confirm the size before i buy a load of them! The cost of the Formula o-ring replacement kits is ridiculous, so will try the ones linked to above if they are the right size.
Posted : 19/05/2013 9:03 pm
Cheers, fakesounding; looks like that is the right size. Think i'll try the bulk order ones, see how they go.
Posted : 19/05/2013 9:06 pm
The full oring kit is silly money but this is all you need:
http://www.chainreactioncycles.com/Models.aspx?ModelID=64927
Afraid I can't conform which it is you need though, I think it's the 2mm but I'm not 100%. OK, it's still a lot for what's probably a 2p part but it brings it into the realm of the sane.
Posted : 19/05/2013 9:08 pm
