Forks...more air or...
[Closed] Forks...more air or more compression ?
[#3856825]
Hi all,
If I run 33% sag on forks it feels 'wallowy' on steep/tech stuff, but great on rock gardens etc.
If I increase low speed compression I get a reverse of the above.
Any advice on what I should be doing to get the best compromise?
(Would it be wrong to run 25% sag and no low speed compression? Would this get round it).
It's a Fox Float 140 RLC
Posted : 10/04/2012 6:18 pm
Is it bottoming out or getting close to?
25% sag is fine
You should get the spring rate ( air pressure) right first and then adjust damping. using compression damping to mask a too soft spring rate gives a harsh unresponsive ride IMO / IME
Locos setup guide is good
http://locotuning.co.uk/tech-info.html
Posted : 10/04/2012 6:22 pm
Thanks TJ. It does seem to blow through its travel.
If I put more air in (25%) do I need to adjust rebound? (I'm thinking it would spring-back quicker than when at 33% sag set at same rebound)
Posted : 10/04/2012 6:26 pm
 mboy
Fox Floats are very linear for an air fork.
The consequence of this is you want to run less sag than you would normally for other forks, typically 25% max where you might run say 30% fine one the equivalent Rockshox.
Posted : 10/04/2012 6:28 pm
If its blowing thru its travel and taking into account what mboy says then more air. there is no right answer - its whats right for you.
check how much travel you get as well
Posted : 10/04/2012 6:32 pm
Thanks guys. So set sag at 25% no compression and go for a spin.
I'll report back in a few days,
Cheers again
(I do love this forum 🙂
Posted : 10/04/2012 6:38 pm
Yeah, more air, had exactly the same on mine. Curiously never had it as bad with old open bath Fox forks.
Edit: This is Mr Toast posting on MrsToast account accidentally. 😡 Glad I posted here and not on one of the more controversial threads.
Posted : 10/04/2012 7:48 pm
 DrP
And yes, more air pressure would require you to increase (slow down) the rebound damping....
DrP
Posted : 10/04/2012 8:31 pm
Woo woo!
Set the front and rear to 25% sag & light/no compression. Took it for a spin round the Peak District:
No wollowy mushy suspension! Tis fabulous. Climbs much better too. Only thing, with having 210psi in the rear shock (to acheive 25% sag), even with the rebound fully on it still feels a little to 'quick.
Does it need tuning? If so, how much?
Cheers guys
Posted : 16/04/2012 7:58 pm
loco is your man
Posted : 16/04/2012 8:02 pm
