Rockshox sektor uturn, coil
Where from, how much, how easy to replace (I've genuinely no idea)
Lbs sold em me, yes perfect for you blah blah but I've bottomed em loads now and that's with the compression one notch off lock out. Could I have a moan at the lbs??
Bump
Tftuned shox,Or Loco tuning will sort you out,Or Get your LBS to order one from Rockshox Uk (Fischer outoor leisure)
Can someone translate?
he's bought a coil fork, and he's too heavy for the stock spring.
Solution: call TF, order correct spring, order some oil (as it's a u-turn spring the rod gets swapped too), replace
TF tuned about £35ish, Easy to DIY (check the SRAM/RS website) oh, and bitch at whoever you like, but for entertainment' sake post back how that goes tho 😉
What language do you want it translated into Al?
non DH-kid-spk GW, thanks.
Firm and Xfirm uturn springs in stock 😀
