Forks for a pre CEN...
[Closed] Forks for a pre CEN Soul?
[#1542047]
What forks are people putting on Souls these days now a lot of the usual choices have gone to 140mm? Phaons are 'tired' and ready for a change
Posted : 25/04/2010 8:31 am
I have Pikes at 120mm on mine but if I had the money I'd put 120mm Maxle Rebas on. I'd have a look at the imminent 15mm DT Swiss XMM120's too.
Posted : 25/04/2010 8:35 am
you 'could' use some 140's, but add a little extra sag into them??
with 20% sag you be looking at under 120mm???
ive got manitou minute IT and have the travel set to 130, but have the extra travel if i change frames atall!- if so it'll most likely be a new soul frame!
Posted : 25/04/2010 8:39 am
140 Pikes. Haven't died yet.
Posted : 25/04/2010 8:40 am
same here, mainly run them at 120mm
Posted : 25/04/2010 8:41 am
reba sl maxle lite 120mm
Posted : 25/04/2010 8:44 am
 rob2
rock shox rev team u-turns.
Use 120mm for general stuff then wind them up for any long downs. Sorted.
Or if too much a fox 120 which is what I have
Posted : 25/04/2010 8:47 am
You know I will never quite get why people think that just because the 140mm forks they are running on a 130mm certified frame haven't caused a frame to fail yet that it means it never will.
Maybe it never will fail but **** me it's not the sort of field experiment I'd want to carry out. 😯
Posted : 25/04/2010 9:21 am
I just went and found some good condition 130mm Revelation 100-130mm dual air uturns, they're an absolutely perfect match for the Soul IMO, they just go together. If I needed new forks tomorrow I'd do the same I guess. Though the new Revs are a bit nicer. Anyone know if you can size down the 120-150mm Revelation Teams?
Oh, I did run mine with 140mm Revelations for a while, no it didn't snap but I went back to shorter ones mainly because I'd feel like such a c**k if it did. I figure that if I was riding hard enough to justify the longer travel, I was probably riding too hard to take a liberty lihe that with the frame... And the 130mm ones got me down aonach mor well enough.
Posted : 25/04/2010 6:32 pm
130 revs,or 120 floats worked best for me.
Posted : 25/04/2010 6:35 pm
I've got coil u-turn revelations on mine. Running them at 115/120 - seems the ideal length to me.
Posted : 25/04/2010 6:40 pm
Running Talas on mine (and mostly at 100mm). Got them cheap on 09 closeout deal. Cant say I notice any problems with them just being QR.
Also run 454 Pikes (again minimum setting) in the past.
I personally find the Talas better suited though.
Posted : 25/04/2010 6:47 pm
Happy to hold my hands up to this being a 'me thing' but don't really fancy idea of second hand forks.
Posted : 25/04/2010 6:51 pm
 tang
running reba team maxle 120s here, sweet. mind you the u turn 130 revs were good also.
Posted : 25/04/2010 6:52 pm
You can get a bike shop to add 10mm spacers into a fox float I think. Therefore reducing the travel to 130mm....
Posted : 25/04/2010 6:57 pm
Just had a trawl around and found some 130 revs. Was intending to go Maxle but can't really spring for a new wheel so got QR version
Posted : 25/04/2010 7:46 pm
reduce a longer fork - revs, floats.
[url= http://shop.18bikes.co.uk/products.php?plid=m14b0s480p697 ]new DT EXM130[/url] - due here in a couple weeks, all being well.
Posted : 25/04/2010 8:12 pm
DT look nice but wasn't really looking to spunk 600 notes - bagged the revs for £300 all being well.
Posted : 25/04/2010 8:14 pm
Reba maxle 120mm for me, seem spot on. Prior to this had DT xmc 130s, which were a bit wandery up hill but great every where else.
Posted : 25/04/2010 8:20 pm
If the revs don't work out, i've got a brand new pair of OEM 2010 Fox Float 32 RL's. Drop me a line
Paul
Posted : 25/04/2010 8:31 pm
Cheers Paul. Will see if shop comes good!
Posted : 25/04/2010 8:48 pm
"Just had a trawl around and found some 130 revs. Was intending to go Maxle but can't really spring for a new wheel so got QR version "
On the short revs it doesn't make a huge difference anyway, they're decently stiff. I ran the 140mm maxles and 130mm QRs, sure there's a difference but not enough to bother me when I went back to the 130mm.
Posted : 25/04/2010 9:02 pm
