Fork travel woes.
[Closed] Fork travel woes.
[#7102155]
I recently bought a set of forks claiming to have 120mm of travel from an online vendor. When they arrived I found them to be the exact same proportions as my old forks which I have always thought of as 100mm forks, is the stanchion measures 120ishmm but the actual travel is 100mm.
The merchant tells me that if I want 120mm of actual movement i need to buy 140mm forks... This all sounds a bit mad to me but it's been a very long time since I bought forks so maybe things have changed..
I just can't imagine manufacturers claiming 120mm and only giving 100mm, any thoughts?
Posted : 01/06/2015 7:27 am
sounds wrong but what are the forks?
Posted : 01/06/2015 7:34 am
The merchant (strange word to use - why not shop?) may be discounting sag.
Posted : 01/06/2015 7:39 am
You've got to say who the merchant is. That is hilarious!
Posted : 01/06/2015 7:40 am
Stanchions being longer than travel is no surprise, they often are, however a 120mm fork should yield 120mm, the measurement of 120mm is the [i]travel[/i] not the length of the stanchion. Sounds like the vendor is a joker. Send them back and buy from someone else.
Posted : 01/06/2015 7:41 am
Thanks for the replies, the fork is a Dart 3 which he reckons he took a spacer out of to bring up to 120mm. My old fork is a bomber z4.
It's a lbs up north that does some online stuff. The forks were originally on eBay but I ended up buying direct.
Posted : 01/06/2015 7:52 am
Sounds like you're being fobbed off.
The 'I removed a spacer' story smells like BS personally.
I've always had stanchion length and travel roughly match, the stanchions are sometimes a couple of millimetres longer but certainly not 120mm long on a 100mm travel fork.
Telling you to buy a 140 in order to get 120mm of travel is taking you for an idiot, send them back and buy elsewhere.
Posted : 01/06/2015 7:57 am
Let all the air out or take out the spring and compress them to see how far they go.
Posted : 01/06/2015 8:39 am
Thanks for the input on this. I have sent them back and have ordered a proper pair of 120mm dual air Reba's. Cost quite a bit more but seems to be a vastly superior fork...
Posted : 02/06/2015 7:49 pm
