Fork stanchion chip...
[Closed] Fork stanchion chip, fix or leave alone?
[#10605899]
Hi
Just put a tiny chip on the stanchion of my pike. It’s barely visible, not much more than a millimetre or so and just the the first layer so still black underneath but you can feel it if you run a finger over it.
Does it need fixing with nail varnish to prevent it worsening or wearing the seal or can I just leave it?
James
Posted : 01/05/2019 6:22 pm
Depends how big / deep it is. I gouged my Lyrik stanchions when a stone got trapped between them and the fork brace. I filled them in as best I could with humbrol black enamel paint. Mine you could see a bit of stuff that wasn’t black though - the humbrol improves the look and I’ve never had air leaking.
Posted : 01/05/2019 7:00 pm
Where is it? In the first 50mm of travel then keep an eye on it. In the top 50mm, you'll probably not need to worry at all.
Posted : 01/05/2019 7:10 pm
It’s about 10cm into 16cm of travel and really shallow so I’ll just keep an eye on it for a while
Posted : 01/05/2019 9:11 pm
Knifing putty or modelling putty can work really well if it’s too deep - then use some VERY fine wet and dry called micro mesh (starts at 3600 goes to 12000) to polish it flat...
Posted : 01/05/2019 9:52 pm
