Fork Seals help!
[Closed] Fork Seals help!
[#921735]
I have an excellent fox vanilla 32 r 2004 but recnetly the oil has been leaking from the right leg quite badly, ive seen seals for £15 so is it easy to do yourself following the disasembley instructions on the fox website? Or should i fork out 90 quid and get tf tuned to do the whole service?
thanks.
Posted : 04/10/2009 8:07 pm
help?
Posted : 04/10/2009 8:28 pm
easy DIY job. I personally like the enduro seals. Been running mine two years. Pulled the fork apart recently and it was spotless inside.
Posted : 04/10/2009 8:59 pm
Yeah easy job job, I used a big socket to put the new seals in straight. I am also using enduro fork seals. You will probaly need some float fluid and fork oil to rebuild the forks with.
Posted : 04/10/2009 9:31 pm
