Fork Oil change
[Closed] Fork Oil change
[#6536806]
I have a 2012 Fox 36 Float R fork and according to the Fox website I need a 10wt Red oil and a 10wt Green oil. Can anyone shed some light on the difference and/or what other brands are worth using?
Also is there any way to add some kid of spacer to them like with a Float rear shock? I've heard of some people adding a bit of oil reduce volume, will this make any difference?
I need to buy some 10 wt oil as all I appear to have in the workshop is 20 wt, would this bu**er them up if I used that instead?
Any help would be useful ta
Tom xxx
Posted : 07/10/2014 3:02 pm
According to Teh Internets the 10W red is silkolene and the 10W green is torco. The Silkolene's pretty easy to find in motorbike shops, Torco not so much, I got a bottle off ebay.
As far as weights- you don't want to put 20W in a damper made for 10W, it might be OK as a bath oil. But I don't know that fork inside so wouldn't want to comment past that.
Posted : 07/10/2014 4:00 pm
