Right
I know this may have been discussed before, but I've got a new spring for my Recon's and was going to change in at work tomoz.
Got the maintenance instructions off the website - question is do I need to remove the oil from the leg or can I just remove the spring and leave the oil in there? The instructions cover all types of recon fork.
Second question - if I do remove the oil - is fork oil a mineral oil? and if so does the oil I replace it with need to be specifically from Rockshox or can I use anything with the same viscosity rating? (we've lots of transformer oil around!)
remove the spring no need to change the oil just grease the new spring.
Cheers jonk - thats what I was hoping.
