Does anyone know where I can purcahse a non-aerosol type fork juice / lube?
Searched high and low but can't seem to find the dripper bottles you could buy a while ago. Maybe my google-fu is weak today.
Can't you use an empty dropper bottle and squirt the aerosol into it?
[url= http://www.tftuned.com/wickens-soderstrom-tf-tuned-no-4-tuned-suspension-lubricant/p3152 ]http://www.tftuned.com/wickens-soderstrom-tf-tuned-no-4-tuned-suspension-lubricant/p3152[/url] ? Contains Nano Particles!
plus 1 TF Tuned, I use their fork oil to lube shock/fork. Use cotton ear buds, dip and apply. Simple easy
Finish line stanchion lube works great. IME anything that evaporates quickly just sucks crap into your seals, best avoided
I use a few drops of 15wt fork oil after cleaning bike, dabbed round seals with a cotton bud. Cycle fork gently a couple of times and gently wipe off any crap which sticks to it. Never had any section issues and never had any signs of wear . Cheap and effective.
Maplin spray silicone grease is what I use, much more effective than fork juice. Even thicker silicone grease is available in tubes, so maybe try that.
The Wickens fluid is the only thing I'd suggest using, very good stuff.
WD40 make a spray PTFE which dries dry... Anyone used that? Are there any advantages with PTFE over silicon?
Brunox Deo fork lube does the job well
