Hi there, after a fruitless search I'm sure the fountain of all knowledge that is STW can help me.
I have a 1999 Marzocchi Bomber Z-4 that came on a Rocky Mountain, and I have finally got round to installing disc brakes.
The IS bracket for the Avid J5 front brake seems from my research to be the IS 51 size. However when I offered it up to the fork, the supplied bolts are too fat for the mount, and also too close togethere.
I have measured that gap between the mounting holes, it seems to be 49mm c/c
So the question is what mounting bracket do I need to fit the brake for a 180mm rotor?
Thanks in advance
Alex 😮 )
Some older forks had this mount. Dunno about adaptors I'm afraid.
OK, so I'm measuring properly. The question now becomes are adaptors still available???
c'mon gang 🙂
Alex
