Any recommendations on who to send a Fox fork and shock to for a service?
Had excellent customer service from TF Tuned recently.
Another vote for TF here.
Yet another vote for TF. However, I used Slick and Slide in Macclesfield recently as they are local and got just as good a service, but with same day turnaround (dropped off at 9am, all serviced and collected at1pm) slightly cheaper, no postage costs and Rick does know his stuff and has all the kit. I'd defo use him again and most of my riding mates use him too
Where you based? Might be someone local who's top notch
Mojo service centre is now Silverfish if you want the Fox UK distributor to service, they will replace all the fork seals, and are the most expensive.
TF probably the largest independant, they are cheaper than Windwave, but on a Fox fork only replace the wiper seals/foam rings/crush washers, oil and other seals "as required" rather than fitting all 3 seal kits.
If you post up your location somebody may be able to recommend a good local place, again check what is done/you want done as not all "full service" are the same.
Another for TF here
Based in south Hampshire, so any local reccomendations?
