fork and brake reco...
[Closed] fork and brake recommendations
[#1389193]
Hi I'm looking to get a cheap set of suspension forks and hydralic brakes that you can adjust the levers can you recommend any
cheers
Posted : 07/03/2010 2:38 pm
what travel fork?
Off-hand though Tora/Marz MX for budget (even cheaper 2nd hand on the classified here), move up the RS range as you can afford it... Recon then Reba or Rev's depending on your travel requirments.
Hydro brakes, my first recommendation will always be to Hope's as you can rebuild them unlike the shimano/magura's that have broken on me in the past and have been impossible to fix (very good brakes but the ability to fix them [cheaply] when they break is more important to me).
Posted : 07/03/2010 2:50 pm
Hi I'm not sure about fork travel I just use the bike mostly on road or old railway lines.can you adjust the levers on hope brakes
Posted : 07/03/2010 3:13 pm
So a short travel fork? Do you really need it?
Brakes - adjust what? Bite point, travel, reach?
Posted : 07/03/2010 3:23 pm
I just measured the forks I ave on now they have about 115mm travel they are fine just want some better quality that have adjustable hardness.
the brakesI have now the levers are loose so you have to pull them a bit before they begin working if that makes sense
Posted : 07/03/2010 3:46 pm
Are your current brakes cable or hydraulic? If cable - new pads or cables required. If Hydraulic - bleed the brakes and/or new pads.
Posted : 07/03/2010 3:49 pm
They are hydraulic.when you pull the lever it pushes a plunger to operate the brake thats were the problem is you have to pull them a bit before it hits the plunger.I want some were you can adsust so the lever is already touching the plunger before you even pull it
Posted : 07/03/2010 3:59 pm
They sound like they need bleeding. What make/model?
Posted : 07/03/2010 4:09 pm
They are Tektro Auriga Comp I got it serviced last week and he said they were ok but it was at halfords
Posted : 07/03/2010 4:30 pm
If they were bled properly and have enough fluid in the travel from pulling lever to bite point is VERY short. They need more fluid or a bleed imo.
Posted : 07/03/2010 4:43 pm
they're not the best brakes in the world, but they can be pretty good if set up properly. A GWT says it sounds like they need bleeding.
Posted : 07/03/2010 4:50 pm
ok cheers I'll try bleeding them .is there any guides that show how to do it
on forks that I see for sale they have measurments for the steer tube where do I measureto find what size I need
cheers
Posted : 07/03/2010 5:27 pm
Chances that your bike has anything but a 1 1/8 steerer are pretty small. What make and model bike is it?
Posted : 07/03/2010 6:49 pm
GT xc3
Posted : 07/03/2010 7:13 pm
thanks for the link for the brakes
Posted : 07/03/2010 7:36 pm
can anyone tell me how to measure the forks so I know what size to get
cheers
Posted : 10/03/2010 1:55 am
tape measure from axle to crown (bit that holds the stanchions at the top below the headtube on the bike) for the length of the fork, measure from crown race to top of steerer for steerer length
Posted : 10/03/2010 7:59 am
