Fork air spring rod...
[Closed] Fork air spring rod easy to compress
[#4372614]
I've just serviced my Sektor fork and put air in, but the spring rod seems quite easy to push in - should it be? Seems like it needs twice the normal air pressure. I haven't fitted the lowers yet.
Posted : 17/09/2012 9:02 pm
[s]That's the negative spring. They aren't particularly stiff normally. It's there to help the fork overcome its initial resistance to moving.[/s]
Actually I think I'm talking rubbish.
Posted : 17/09/2012 9:05 pm
Thanks, I'm having a senior moment, but what makes the spring stiffer when the lowers are fitted? If the air's in, the rod's the only moving part isn't it?
Posted : 17/09/2012 9:09 pm
See my edit. Perhaps it moves more easily now it's been serviced? Put it back together and see how it is?
Posted : 17/09/2012 9:14 pm
Cheers. I've put 70psi in it and I've also filled the damper leg with oil and will leave it overnight. Neither air or oil are leaking so far.
Posted : 17/09/2012 9:23 pm
