Fork advice
[Closed] Fork advice
[#11400822]
Buying a new forbidden Druid frame. 29” 135mm travel. What 150mm fork would you put on it? I ride lakes, weigh 10st 5lb. Never ride park. 150 pike, Lyrik or fox 36 performance.
I have a 27.5 160 pike at the mo and that seems good enough. Would the Lyrik Or 36 be heavy and overkill??
Posted : 26/09/2020 11:20 pm
 poah
I'd put a mezzer on it and reduce travel to 150 - great air spring and damping.
Posted : 27/09/2020 10:59 am
Why not just upgrade the internals of the Pikes if you find them stiff enough....Fast upgrade,smashpot coil,Push ACS will all make the fork better... What model and year Pike?
Posted : 27/09/2020 11:09 am
It’s a 2018 with a 2021 spring. It’s 27.5 can these be upgraded to 29??
Posted : 27/09/2020 11:34 am
Are the mezzers that good. Struggled with manitou reliability back in the day. Are they better now??
Posted : 27/09/2020 11:35 am
More ball ache than its worth, buy new the frame deserves it
if it was me I'd put a lyrik on.
Posted : 27/09/2020 12:02 pm
 poah
They are a very good fork. never had any problems with my mattocs either (or any other fox I've owned in the last 4 years RS pike, sid and fox 34)
Posted : 27/09/2020 2:18 pm
Can’t go wrong with a Lyrik RC2!
Posted : 27/09/2020 3:08 pm
lyrik ultimate is great fork and so easy to get dialled in, can't go wrong.
Posted : 27/09/2020 3:34 pm
Are 150 29” pikes too flexy??
Posted : 27/09/2020 4:12 pm
Sometimes a certain fork feels "ok" or "enough" with a certain bike but that can change if you swap for a more capable frame.
Some years ago I had a Fox 34 on a somewhat conservative trail hardtail and the fork felt perfectly ok. Then I upgraded to a Pipedream Moxie and suddenly the 34 started feeling like a wet noodle.
All this to say that your feeling that the Pike is "enough" might radically change with the Druid, and, IMO, that frame seems to deserve a very capable fork
Posted : 27/09/2020 4:50 pm
In the spirit of recommending what you have, I'd put a Cane Creek Helm Coil on there... 🙂
Posted : 27/09/2020 4:57 pm
I've just gone from Pikes to Lyrik ultimates and it is night and day regarding the stiffness between the two. It was a close call between the Lyriks and a set of Ohlins from JTEC but I got the Lyriks at a bargain price so that was that.
Posted : 27/09/2020 6:37 pm
my mate is on a druid at the moment(gets given a bike to race on each year) and it came with a dt Swiss fork. took him a while to get it setup right and then something went wrong and it needed sending of for repair. while waiting the shop put on a lyrik ultimate which he had for about a month, lots of fiddling to get it setup and never fully happy and then when he got the dt fork back said it was a massive improvement over the lyrik.
Posted : 27/09/2020 6:55 pm
Great fork on paper and Poah seems to have a good set but after two bad sets and zero support in the UK, it will likely be another 20 years before I'm willing to give Manitou another go.
I bought a Lyrik Ultimate instead, and it was cheaper. Maybe not as good on paper, but way better actually on my bike.
Posted : 27/09/2020 9:40 pm
re manitou - sounds familiar....
Posted : 27/09/2020 11:10 pm
I'd put some of the new Suntour Durolux on it, partly because they're supposedly a really good fork and partly to watch the reactions of people when they see a Forbidden with Suntour.
Posted : 27/09/2020 11:28 pm
