Has anyone got one of these forks?
If I use the fox psi table for my weight I end up with about 5mm of sag. Most of the other fox units have about 110psi but the Talas units have a figure of 175 psi ( I'm a fat knacker!). If I drop the pressure down to about 100-110 psi it seems ok.
The fork also loses pressure when I disconnect the pump. It's not just the pressurised air in the pump as the pressure will be about 20 psi lower if I reconnect.
Is there an issue with these forks I should be aware of? Any solutions ( other than buying Rock Shox fork)?
Don't worry about the number just set the sag as required. I find as you when I remove the pump the small amount of air lost when removing the pump made a difference.
5 weeks after getting them I'm still not 100% where I need to be running less sag to get less dive.
