£30 or £300, people are questioning why the warranty period is so short.
Perhaps the seller doesn't want the hassle of dealing with warranty returns, and hopes 30 days will be long enough for post to work before it breaks?
Any news, signed up for email notifications and not got anything yet!
Well I've been using one of the vario force ones from the op since Xmas and it still works.
I believe the construction is similar.
After wet rides it gets sticky- it needs lubing intermittently.
Once the cable tension is set up it works consistently, but if it goes out for any reason mid ride you can have a post that won't go down or worse won't stay up- easy to adjust with allen key though.
If you ride sat down a lot I can see the metal retaining pin wearing out/becoming "grooved" where it engages in the post. Could lead to problems in the long run.
It requires a different technique to raise and lower it to the joplin I have on my other bike. Need to have weight on the saddle when pushing the lever in order for it to disengage (?due to wear as above), but it's easy to get used to.
Hi all, apologies the 30 day warranty posted was in error. A seatpost that lasts for 31 days is probably not fit for purpose. If you break it in normal use in 12 months I will fix it (excluding wear and tear / incorrect use). Beyond 12 months full spares are held and will be cheap. I will update the website to this effect.
The bushing material in the TrailDrop is different in attempt to combat this. I routinely clean and grease mine every other wet ride as per service schedule - takes 5 mins max. The dirt boot is essential in the UK.
The latest TrailDrop has a fixed cable and inline cable adjuster to make this easy to adjust on the fly.
This is a 'feature' of the mechanical design. The spring is pushing the inner post up against the pin. With this force it is difficult to pull the pin out. Weighting the saddle counters the spring force and allows the pin to come out easily. As you say, easy to get used to and other mechanical pin seatposts are the same.
Thanks to the owners of TrailDrops for posting up their experiences 🙂
was - news I wanted to hear 🙂 Next time a shipment drops, I'll most likely get one.
Let me know when you get stock as I am interested - cheers
Ash
Just a quick update to say my forca vario dropper failed at the seat clamp last week. The through bolt that takes the 2 bolts that clamp onto the seat rails snapped around the rear bolt hole. Probably due to the seat being too far back and me being rather heavy (92kg) as the seat rail has also bent slightly. I've emailed the German seller to see if a spare part is available but thought I would post up on here as a bit of a long term report.
Shame co I was enjoying using it.
Does anyone have a link of where to buy them?
Thanks toons - so about £70 all in. Probably worth a dabble.
having a dabble with a suntour pop lock remote instead of the stock lever as i can't seem to find a comfortable position on the bars.should work, all it does is pull a cable. 12 quid from taiwain.
Any updates on availability or development of a bigger drop post?
Any more user problems?
I'm very interested in these too now as I've gone back to a 27.2 .
Deliberate Thread resurrection here.
Does anyone have any real life experiences? Are they available still?
I had the one from here http://www.bigmassive.co.uk/
A bit more that the Forca one but as far as I can tell pretty similar. I think they are both modeled on the GD classic.
Basically it is a well made bit of kit and does the job. Personally, and this could well just be me... I found it a bit awkward to use.
You have to apply a little bum weight to the saddle to hit the remote then you can push it down. When you want it to pop up you again apply said bum weight and stand quickly to allow it to come up and click into position.
I just found that difficult to do very quickly. I used it on local rides in Yorkshire then round trail centers in Scotland. Locally it was fine but round the trail centers where the terrain changes very quickly I didn't think it was a fast enough system. User error?! Maybe.
I got a good deal on a GD turbo, which does not need any (pre release) weight when you want the post to go up or down. I find it a great system, much easier and I find it much faster to use on the ride.
I should mention I had tried a friends Reverb before moving to the GD. It just worked and worked fast..thats what I was after in a post. Not available in 27.2 so the GD T was my best bet. X fusion do one but the hit and miss reviews put me off.
I have come to think that spending more is a bit of a sting but worth it in the end.
EDIT: one thing I do like about these cable remotes is the fact you can look after it yourself. Simple construction and spares available. Part of the reason I chose the GD.
I purchased one of these new on ebay from a foreign supplier and had continuing problems with it from day one. At first it stuck when I did the seat clamp up (5Nm). I contacted the supplier and they suggested stripping it and increasing the spring pre load. I did this and had to remove a jammed piece of plastic whilst I was in there. Unfortunately it then started sticking on the first ride, after another strip down it was returned to the seller and another one sent out. THIS WAS EXACTLLY THE SAME. I emailed photos and videos to the supplier and eventually returned the second post. At this point the seller refused to refund or replace the part because they were unhappy that I’d given the product negative feed back. So far I’m out the price of the post and two lots of carriage charges and don’t even have the dam post! These are very poor quality supplied by a dishonest company that hides behind ebay.
Which post was this? There are different versions being sold by both uk and international sellers.
Forca, ICE v8, TMARS
Your first post on singletrack i see 🙂
I'm looking at a TMARS one.
Any reviews on this type?
It's a bit odd to register with a forum just so you can name and shame, then not name the supplier.Your first post on singletrack i see
Anyway, back on topic, I see that BigMassive no longer do trail droppers
Hi, yep, first ever time using a forum but I noticed other people might be considering one and thought I should say some thing. It was the Forca Vario from innovation-store on eBay.
