Flat Mount Brakes o...
[Closed] Flat Mount Brakes on Post Mount Frame / Forks
[#9684707]
Is there an adapter that makes it possible?
Posted : 24/11/2017 12:08 am
Yes
Posted : 24/11/2017 12:13 am
Ta, got a linky?
My Googlefu has only turned up the reverse adaptor
Posted : 24/11/2017 12:18 am
probably possible but the adapter would need to be pretty awkward.
If you look at this:
you can see how the flat mount is aligned with the fork / stay. To get this alignment on a post mount would need something that offset the caliper and rotated it so it had the same alignment to the axle. I haven't seen such a thing but it may exist
Posted : 24/11/2017 12:33 am
Pretty sure it doesn't exist. I have this issue with my caad 12 disc fork. Why would they make a flat mount rear with post mount front. Had to buy a separate post mount caliper for the front.
Posted : 24/11/2017 12:59 am
Wrong way round Pete.
You CAN adapt flat mount calipers for post mount frames but not the other way round.
Posted : 24/11/2017 7:13 am
+1 (next to) Impossible
There is also the fact that the FM caliper is bolted from the opposite side of the adapter - it has two threaded holes, as opposed to two eyelets in the case of IS and PM calipers.
Posted : 24/11/2017 7:32 am
Why has flat mount come about? Is it for aesthetic reasons on road/gravel bikes? And is it likely to find its way to MTBs?
I've been looking at gravel bikes and I prefer the look of those with flat mounts, I did read a comment that they can cause problems aligning the caliper, whereas post mount is more adjustable?
Posted : 24/11/2017 7:49 am
This was the first result from Google.
[url= http://www.bikehugger.com/posts/road-disc-brake-tech-flat-mount-vs-post-mount/ ]Flat mount versus post mount[/url]
Posted : 24/11/2017 8:09 am
Probably because they could only source the fork with post mount.
This is the factor that differentiated between the two final frameset on the shortlist, when I built my road bike, last year.
Didn't want a fugly bodged caliper mounting solution, so went with the frameset that had flat mount front and back.
Posted : 24/11/2017 11:33 am
