Can anyone help me source decent flat sockets or well proved suitable spanners for servicing rockshox forks?
RS make the mission control spanner for a lot of money and there's a firm in the states making bespoke tools that once Duty has been added get kinda pricey too. Just wondering if there's anyone out there turning regular sockets down with a lathe or knows of a source for cheaper alternatives?
Park do a 24mm cone spanner which is ideal and IIRC about £7. (I got it so that I could take boxxer dampers out without having to remove the fiddly dials, but it's the same job essentially).
I bought a 24mm for my Maverick forks from eBay, there were loads to choose from mist <£10
Cool, so i just need one of these:
http://www.fatbirds.co.uk/2209/products/park-tool-scw24---shop-cone-wrench.aspx?origin=pla&kwd=¤cy=GBP&gclid=CLrti-67-cACFfSWtAodnEYA_w
Great idea.
Loco sells em - doesnt he?
I have a spanner for taking shower fittings off its basically just a thin spanner aka cone spanner.
http://www.toolstation.com/shop/Compression+Fitting+Spanner/p62263
Its a bit on the short side and not the most ergonomic but if you're in a hurry it'll get the job done. Otherwise if you can wait a few days I'd go for the park cone spanner.
I've got a 24mm socket that fits a 1/4 inch drive ratchet that does just great. You can buy them in singles for less than a fiver. Old skool combination ring spanner and the ability to hold it on and work carefully will also remove them.
Scapegoat, and links to your 24mm sockets?
I just bought a 1/2" drive 24mm single hex socket and ground it flat with a hand file. Took a little bit of work but works perfectly.
Bench grinder and a normal 24 socket for me.
I made an arbor from a coach bolt, spun the socket up on a cordless drill and flattened a 24mm socket on the bench grinder, worked a treat.
Plumbing wrench off ebay for a couple of pounds
[img] https://encrypted-tbn2.gstatic.com/images?q=tbn:ANd9GcQYsffdaeu_8T1aVne20ovD1YWY-0j3-E4OY_xxkNFl6WDsD0fN [/img]
