Fixing torn tubeles...
[Closed] Fixing torn tubeless sidewalls with those slug things
[#7118888]
Just had my first experience of fitting a slug thing to my tyre. Luckily, I still had the instructions and it went in without too much hassle, and the tyre inflated. Despite trimming to approx 3mm proud as stated in the instructions, by the time I got home, its sticking out quite a bit more. Should I trim it again? Is it safe to leave in forever now, or is it just a temporary fix?
Posted : 08/06/2015 11:51 pm
Jam another one in or just patch the tyre now your home. Ive torn a side wall and used 3 of them to seal it must of been a month before i patched the tyre.
Posted : 09/06/2015 12:12 am
Where do people get the anchovy/slug things from?
Any preferred makes?
Posted : 09/06/2015 3:36 am
I've used weldtite and never bothered to patch them later.
Posted : 09/06/2015 6:24 am
I've had 1 in 5 fixes fail - done right and for the right hole they're a permanent fix.
I got a load of generic ones off ebay much cheaper than repair kits - the weldtite kit is good, though.
Posted : 09/06/2015 6:55 am
IME the worm will work its way out of 1 in 10 holes, probably as the hole is too big. It'll get you home, maybe even last a few weeks but you'll want to put a patch in from the inside.
Posted : 09/06/2015 9:01 am
Cheers.
I'll get the tyre off and patch it then....
Posted : 09/06/2015 1:38 pm
what patch for the inside of the tyre then?
Posted : 09/06/2015 1:41 pm
Bin dun recently. [url= http://singletrackworld.com/forum/topic/patching-tubeless-tyres ]http://singletrackworld.com/forum/topic/patching-tubeless-tyres[/url]
Posted : 09/06/2015 2:47 pm
I've used regular inner tube patches before but managed to pinch puncture one of those too 😆
For something tougher I'd try a tyre boot. So long as it holds, the sealant should be able to do its job.
Posted : 09/06/2015 2:55 pm
