Fixing shimano shif...
[Closed] Fixing shimano shifters- will it expode?
[#2756431]
LH shifter (XTR M970) has been problematic for a while, it sometimes doesnt let the gear cable through when changing into the granny ring (same with different cables and F Mechs). I press the lever and nothing happens like somethings stuck internally. Are they take apartable ? I remember taking the guts out of a 7spd one years ago and it was a *bit* complex.
Posted : 16/05/2011 10:26 am
 Alex
I took my XT ones apart a while ago when the end of the cable sheared and wouldn't come out. Wasn't too bad at all but I never got as far as removing any springs or anything.
Bit of a faff, but definitely doable to see if anything is obviously wrong.
Posted : 16/05/2011 10:27 am
On the ones I've had a look at (90s 7s) there's a reverse-thread nut to come off and I think most of the stuff underneath can be held on if you're careful.
Certianly worth opening up and seeing what's going on - you may not need to dissemble to diagnose.
Posted : 16/05/2011 10:57 am
They're fiddly but if you're mechanically minded, you should be ok.
I'd suggest taking it apart in a plastic bag or similar to catch any small parts that fly out 🙂
Posted : 16/05/2011 10:59 am
 gazc
with my old xt's (not latest ones) stripping the case off and giving it a good old dose of gt85 helped to free up the crud that got in the mechanism and jammed it without having to take it to bits any further - maybe worth a punt before you unleash the springs and ratchets! 🙂
Posted : 16/05/2011 11:05 am
