Fitting tri bars to...
[Closed] Fitting tri bars to mountain bike?
[#6964078]
I want to fit a pair of these to my mountain bike for my bike packing trips.
http://www.bike-discount.de/en/buy/control-tech-aero-cockpit-plus-carbon-162259
The issue is that the clamps are 31.8mm diam with a 70mm spacing. I am struggling to find straight bars where the 31.8mm diameter section is that long. Most bars I have found seem to start tapering off before 70mm.
Anyone know any straight or low riser bars that do have a longer 31.8mm diam section at the clamp area?
Thanks
Posted : 29/03/2015 1:01 pm
I found some adaptors online that increase the thin part of the bars to make them over sized, I cut them down a bit and grinded the inside to go over the slope, then rapped electrical tape around them for when I need to do the same for longer rides, they work a treat.
Just had a quick search on line but can't see them, sorry
Posted : 29/03/2015 1:27 pm
Here you go search for "handlebar shim"
http://www.chainreactioncycles.com/vision-tt-clip-on-bar-shims/rp-prod36423
Cut them to suit (I cut mine in half), grind the inner to match the slope on your bars, wrap with tape and the jobs done
Posted : 29/03/2015 1:31 pm
Why not just get something a lot simpler, a pair of bars that can be set up as far apart as you want?
e.g. http://www.bike-discount.de/en/buy/profile-design-t2-aluminum-aerobar-219599/wg_id-484
You might then want to "customise" them for length too.
Posted : 29/03/2015 5:07 pm
