Fitting Torque Caps...
[Closed] Fitting Torque Caps to Hunt Trail Wides
[#11066123]
I’ve got a trail wide with 15mm caps fitted and a set of torque caps. I’m trying to work out how I should be fitting them.
There’s a wee rubbery o-ring inside the adaptor wand it looks like it should handily slip over the existing endcap.
So, bit of grease and jam them on? Does the lip on the adapter face in or out? Looks like it should be in, to act against the existing endcap?
Posted : 26/02/2020 8:29 pm
In as you say
Light grease for o ring
Once pushed on they can be a loose fit
Posted : 26/02/2020 9:44 pm
Exactly as.
I probably went a little overboard with grease even though it was a very thin bead. They really don’t need much grease!
Posted : 26/02/2020 11:24 pm
