Fitting Superstar O...
[Closed] Fitting Superstar Oval Ring
[#7630695]
Website says fit with marker aligned with crank. There are four marks on the ring FFS... which mark aligns with the crank?
Also - I want to fit this to a triple spider. I had a Hope NW ring on before which went on with normal chainring bolts. This oval thing has built in threads - but also has a 2mm offset - will that work on a triple spider?
Anyone fitted one of these on a triple spider?
Posted : 06/02/2016 4:40 pm
Anyone?
Posted : 06/02/2016 5:41 pm
 lerk
It should be tallest when the drive side crank is pointing 2 o clock...
Posted : 06/02/2016 5:48 pm
I was struggling with this last night! The marker is a small ^ shape sticking out on the inside of the chain ring. I've fitted mine to the middle of a triple chainset no probs.
Posted : 06/02/2016 6:07 pm
Cheers for that.
Like this:
Posted : 06/02/2016 6:09 pm
Right - I was looking at the printed marks.
Posted : 06/02/2016 6:20 pm
Timely as will be fitting one when I get round to it. When I opened it I also wondered where the indicator was. Given its oval, getting it right will make a difference.
Posted : 06/02/2016 9:12 pm
