Any top tips for removing old grips, and fitting new ones? I've heard something about using hairspray?
Oops double post
Thanks Foxyrider - super helpful.
cut old ones off with a stanley knife fit new with hairspray as it sets
I use a track pump to lift of my old ones - I don't use lock-ons though. I would have thought it doesn't work with those.
I dont see why everyone isnt using lockons now they make life 1000x easier, what am i missing?
cut em off - disc brake cleaner them on
Narrow bladed screwdriver under grip edge, slide in straw off can of WD40/GT85. Squirt a little in. Pretty quickly gives slack under grip, either work it round or push straw in further and/or add another squirt. Keep going and they soon slide easily off.
I wouldn't (personally) cut off as it'd probably score the underlying metal with the blade tip. Not saying this is significant but I'd rather avoid doing so.
Discard new packet of regular grips and go spend some more money on lockons, just a whole world easier and quicker. IMO life is just too short to fanny around with "old style" grips / hairspray / spray paint etc 😉
I don't use lock ons because I don't like the collar at the end of the bar pressing into my hand, plus I don't have problems with 'spinny' grips anyway.
Another user of hairspray, I have a dedicated Tesco Value can and no one in the house uses the stuff normally.
Use a small allen key or similar to spray some under the grip, rotate to work it off. I have also used, sticking the bar in a bowl of hot water to get some more difficult ones off in the past.
They're much heavier than ESI or foam grips, and some of us have our weightweenie pride!
Electrical tape on the bars wash the grips out with petrol or disc brake cleaner and slide on. The petrol melts the glue in the electrical tape to leave a very sticky mess and bonds them on strongly. If you are still worried about them slipping lockwire them, at two or three places on the grips wrap the wire round twice and twist the ends round until tight not forgetting to cut off the excess and push the end into the grip to avoid it snagging your glove.
If you do decide to go down the lock on route 20 euro cents fits very nicely as a bar end!
Iain
I don't use lock ons as I often grip the very end of the bars on climbs, and I don't like the rings digging in my palms.
Hairspray, cheaper the better, more glue, less perfume.
Foxy, they look exactly like my Ragley ones, 'cept they say superstar on, how much do those ones cost?
I use tf2 / gt85 on and off, although now using lock-ons (which required a hammer...)
yep lift a bit up with a knife or something and spray hairspray into the grip and twist off 😀
"I dont see why everyone isnt using lockons now"
Not as comfy, really. A little more expensive too. But agree they make fitting so easy.
fitting lock ons needed a hammer? we're talkin about fitting a set of grips here?
a bit of elbow grease is the only lube you should need when takin your old grips off, worst case scenario cut em off...
as for the new uns, just fit them dry and gradually work them on, it's all technique.
Changed my grips to lock-ons yesterday for the first time. Hard to see why this isn't the best solution for grips. So easy.
And if you're gripping the end of the bars, surely it's time for some sort of bar-end on there? Even short ones make all the difference.
£7.99....Quite a few colours out of stock at the mo tho....not a problem if like me you just want black ones 8)
[url= http://stores.ebay.co.uk/Superstar-Components-Tibolts_Grips_W0QQ_fsubZ1075913012QQ_sidZ543716692QQ_trksidZp4634Q2ec0Q2em322 ]I get mine via their eBay shop.[/url]
Aside from the obvious difference (they say Superstar on), Ragley grips have a solid alloy end cap, rather than an open end with a plastic plug that I think Superstar are using. This was important to me when I specced them. It might not be important to you.
I used this open design on the Brand X grips for CRC too - http://www.chainreactioncycles.com/Models.aspx?ModelID=40745
All grips mentioned here are made by Propalm - http://www.biketaiwan.com/database/tbdb.asp?custid=001080
For folk worried about comfort, you can get [url= http://www.pedalon.co.uk/acatalog/bonti_rl_slim_grip_blk.html ]single sided lock ons[/url]?
Why would I want to bother if I don't have a problem with spinny grips?
p.s. [url= http://www.biketaiwan.com/database/adshow.asp?t=tbs2010&p=902 ]Swarovski crystal encrusted bar ends![/url] (from brants link)
Oooh, they do a clone of the (£40!) Brooks leather grips too.
The new design ODI Lock-Jaw end caps are great. So much more comfortable than the old plastic screw-in jobs. Shame they aren't retro-fittable. And £11 for replacements.. ha ha.
Also Gee Atherton didn't want any end-caps so specced these for Pro http://www.chainreactioncycles.com/Models.aspx?ModelID=44923
