Help!
I've just bought the bits plus the tool to replace the fixings on my rear shock. The instruction here [url= http://www.tftunedshox.com/files/shock_bush_removal_fitting.pdf ]http://www.tftunedshox.com/files/shock_bush_removal_fitting.pdf[/url] shows this specifically for the 'rebound adjustment' end of the shock but is the process the same for the other end?
This is probably a daft question but I want to make sure I'm right before proceeding.
TS
from my experience there's not usually a 'hoola hoop' type bushing to replace at the other end, just the mounting kit which should be ok.
Sorry, I should have been clearer. My main concern is in using the tool to push the bushing out at the other end. Is that correct?
It's the same both ends. The holes are the same size.
Tremendous <gets vice back out>.
Fixed - woo hoo!
Cheers folks
TS
