Fitting internally ...
[Closed] Fitting internally routed hoses?
[#10164655]
I'm hoping to pick up a Whyte hardtail tomorrow it comes with xt m8000 brakes that I want to swap for my saint m810. Providing the hose is long enough I'd like to swap them.
Any tips? I've seen a couple of you tube vids.
Posted : 12/08/2018 6:39 pm
Leave the hose in place and swap the callipers and levers over.  Bleed.  Job done.
Posted : 12/08/2018 6:42 pm
Thought about that but want to sell the XT brakes so don't want to give them old hoses.
Posted : 12/08/2018 7:42 pm
Tape the new hose to the old one, or failing that, at least attach a piece of string so you can pull the new hose through.
Posted : 12/08/2018 8:09 pm
Get a double ended barb like the reverb one, attach to old and new hoses and pull the old one out and the new one in at the same time.
Posted : 12/08/2018 8:14 pm
Due to the banjo at the calliper end, I doubt the techniques above will work.
If you remove the olive and barb, you should be able to insert the end of a gear cable into it, and secure with a wrap of tape.
Pull hose out of frame from banjo end, making sure that the nipple end of the gear cable doesn’t disappear inside the frame - you could thread a washer onto the cable beforehand to prevent that.
Swap hoses on the cable, re-tape and pull it through from the other end of the cable.
Should work?
Posted : 12/08/2018 8:35 pm
I'll confess to dropping down to my mate int he bike shop and getting him to do it 🙂 Much simpler as it needed to be shortened and bled too
Posted : 12/08/2018 8:38 pm
I'm tempted to ask the bike shop to do it, but I like learning these things.
Posted : 12/08/2018 8:49 pm
