Fitting I-spec a sh...
[Closed] Fitting I-spec a shifters to I-spec 2 brakes...
 DrP
[#8047896]
I can't seem to find an adapter to fir my 10speed shifter to my newer xt brakes...
Matchmakers are for shimano-sram...I suppose I could try to modify them?
Has anyone mated these unlikely lovers together before??
DrP
Posted : 11/09/2016 6:12 am
Hmm. I've got I spec shifters on 2 types of brakes. One with indent inside the clamp, one without. They needed different methods - one needed a little bar with a threaded hole in the side. Has your lever got the little indent inside the clamp?
Posted : 11/09/2016 9:50 am
I also fell foul of this exact problem! Couldn't find a solution so brakes will probably be going back!
Posted : 11/09/2016 9:54 am
I changed mine last year - new brake lever, XT, and original ispec shifters. There was a Shimano conversion kit with various bolts and adaptors available at Wiggle. Worked a treat.
[url= http://www.chainreactioncycles.com/shimano-xt-m780-i-spec-direct-attach-cover/rp-prod67257?gs=1&gclid=CjwKEAjwgdS-BRDA7fT68f6s8zMSJADZwHmvwwpFAfGovBthZb1GlsLEbMwekQ0rxr9ScUbT_9STiRoCUc7w_wcB&gclsrc=aw.ds ]here it is[/url]
Requires changing the top plate of the shifters, all parts are in the kit.
Posted : 11/09/2016 10:25 am
Are you sure? It specifically says in that link "2nd generation Ispec B". What model shifters/brakes did it work with?
Posted : 11/09/2016 10:31 am
Shifters are 2013 XT780 and brakes are 2015 XT785
Posted : 11/09/2016 10:40 am
Yours are Ispec b shifters though, not A like OP & me!
Posted : 11/09/2016 10:46 am
Ah, OK, apologies for confusion
Posted : 11/09/2016 10:55 am
