Fitting hope headse...
[Closed] Fitting hope headset
[#1637101]
Hey,
I have just purchased a hope headset and was wondering how to fit it? I have cleaned up my old headset before, but the hope headset is just different.
Do I need some specialist tools?
Just wondering if its a job I can do myself or best to take to a bike shop? No point spending a fortune on a load of tools.
Rob
Posted : 24/05/2010 10:49 am
Main tool you need is the headset press to fit the cups. You could make one yourself they're not difficult. Or you could use the gentle tapping with a hammer. Going one step further you could get the headtube faced to make sure the bearings are parallel - I had one bike done and it was smoother but it's not important that you do it.
Posted : 24/05/2010 12:45 pm
Ta 🙂
Posted : 24/05/2010 1:06 pm
 tf
This is also a great way to permanently knacker your frame; either make a press, or buy one (rudimentary headset press is like £30), it's well worth having if you are going to do this more than once (it takes 3min to fit the headset with a press).
Posted : 24/05/2010 1:22 pm
Does the job just fine if you're careful (and actually usually even if you're not).
But you can easily make a press with some threaded rod (M10 size) and matching nuts and washers.
Posted : 24/05/2010 1:25 pm
If you'd bought the headset from the LBS in the first place they may well have fitted it for you.
Posted : 24/05/2010 1:50 pm
