As the title suggests, is Windolene suitable for fitting ESI Grips?
Also, the bar-ends seem to be a tight fit and quite difficult to install.
rubber hammer for the bar end...
not tried Windolene, but alcholoic hand gel works a treat.....
i just use a bit of spit on the bars....slide on no problem and dont move once dried.
windolene works, trim the end caps flappy bits with a stanley knife if they don't fit in your bars, alternatively buy some nice ones cos the ESI ones are mingin...
Use an air compressor works every time.
+1 for spit
I use windolene for mine, seems to work fine.
stu , dont you have some work to do ? 👿
Thanks folks. Rubber mallet and windolene at the ready. Quite like the end caps, they match my kashima shock and forks 🙂
