Fitting Avid Juicy ...
[Closed] Fitting Avid Juicy 3 to Marzocchi MX Comps - What'm I doing wrong ??
[#1951489]
Hi all
Help ! I have a set of Juicy 3's that I am fitting to my sons bike with Zocchi MX Comp forks, I can't seem to get them to fit well, its almost like they are different distance apart. Should I use the concave/convex washers (its seems a bit jerry rigged doing it like that)?? Or have I got it completely wrong ??
Also, will this combo work with a 185mm rotor ? Or is a 6" the max ?
Any help, very gratefully received !!
Thanks Sean
Posted : 01/09/2010 3:10 pm
Yes, you should use the Concave washer with Avids, but also sounds like you might be using the wrong size brake adapter.
Posted : 01/09/2010 3:15 pm
 Xan
[s]Sounds like you are using a split IS mount and tried to fit it to a Poast mount fork? If so you need to buy a Avid post mount adaptor. Costs about £10 from most LBS. Or am I insulting your inteligence. You can get these adaptors in 165, 185 and 203mm sizes.[/s]
Ignore me I read your post right this time
Posted : 01/09/2010 3:16 pm
There is no brake adapter on at the moment, just a standard disc block and rotor (165mm) but I also have a 185mm adapter and a 185 rotor, but I can't get that right at all.....
I'll try it at 165mm with the concave washers. Is it just a case of hit and miss ?
Posted : 01/09/2010 3:32 pm
Avid Brakes are really easy to set up using the Concave Washers, also Avid Rotors are 160mm, I still can't visualise why it doesn't fit, can you post a picture?
Posted : 01/09/2010 4:56 pm
It was the concave washers I was missing ! Much more straight forward now !!
Now I just need to get the bloody things bled !
Posted : 02/09/2010 12:02 pm
