fitting a headset t...
[Closed] fitting a headset to triple clamps
[#746175]
hi everyone
i seem to be having a problem i have some marzocchi shiver triple clamp
and i have just got a chris king headset
but the bolt out of forks does not fit through the top of the headset
and the headset bolt is far to short due to being triple clamp
is it possible to buy a bolt that will fit through the headset that is long enough for triple clamps also if i change the bolt i will have to change the nut at the bottom of the forks
i am most likely not making any sense
but thanks if you can help
Posted : 30/07/2009 12:01 am
less sense there
i think you have a head stock/lock and the long bolt (6-9" long) is wider than a std m6 bolt used in a std starfangled nut
either a new top cap or fit the starfangled nut
Posted : 30/07/2009 12:06 am
