First time single s...
[Closed] First time single speed, help needed
[#1309415]
Going to go single speed for the first time, what gear ratio is common or a good starting place?
Posted : 09/02/2010 9:04 pm
32:18 to get used to it and then move to 32:16
Posted : 09/02/2010 9:05 pm
32:16 or 17 or 18 but usually 16
Posted : 09/02/2010 9:06 pm
i ride round sherwood forest a lot and find 32-15 ok. seems ok for round that way, nothing too taxing
thinking of going to 14 in the summer when conditions should be better.
but then again i have got big legs 😆
Posted : 09/02/2010 9:16 pm
what type of riding are you doing is it mostly flat or v hilly
Posted : 09/02/2010 9:25 pm
Im in Kent so not too hilly, mainly rolling singletrack, with an occasional short sharp climb
Thanks for the replies
Posted : 09/02/2010 9:27 pm
I run a 32:16 which works for me
Posted : 09/02/2010 9:30 pm
two to one gearing, if you are riding big hills or lazy(like me) add one tooth to the rear.
I usually ride 36 19. It's taken me all over dartmoor, exmoor, quantocks, haldon.
I think if you use an odd number of teeth one end or the other it lessens the wear, something to do with numbers...
Posted : 09/02/2010 9:31 pm
if its not that hilly i'd be inclined to start with 32-16, then see how you go.
Posted : 09/02/2010 9:32 pm
32:16 fine round here but find a wee bit low geared on the flat but just high enough for the ups. Be what I would probably say to start of with.
Posted : 09/02/2010 9:34 pm
yeah! be prepared to spin on the flat 🙁
Posted : 09/02/2010 9:36 pm
Built mine last week end up 36-16 great on the road. But killer offroad. my 32 comes in the post tomo!!![I hope] 😀
Posted : 09/02/2010 9:37 pm
I live in Kent too, and would say that 32:16 should be fine for most off road conditions round here. Have cleared muddy climbs on the North Downs in that ratio, and generally only have to push on stuff that I'd be walking on a geared bike anyway. As others have said, maybe go slightly higher if you do a lot of road riding and don't want to spin out too much (or build another singlespeed for that!).
Posted : 09/02/2010 9:56 pm
I don't understand - nobody actually rides SS, so put on any gear you like 😀
Posted : 09/02/2010 9:59 pm
I assume you ride a geared bike at the moment? Ride round in one gear for a bit, middle ring and 16 or 17 on the rear and see how it feels. Then use that to judge what ratio would work for you best. Personally I am a 32:16 kind of guy but horses for courses.
32:16 here, gets me around most of Afan. I did the ride in one gear for a bit thing to figure out the best place to start and found that useful.
Paul
Posted : 09/02/2010 10:03 pm
you are correct you do need help
Posted : 09/02/2010 10:19 pm
The correct ratio is the one that works best on the rolling singletrack that you ride. That's what you need it for, and you learn to put up with the high gearing up hill or low gearing on the roads.
I usually ride 34:18 at Cannock Chase (3 times a week) or CYB, Llandegla etc. but would go 36:16 at Thetford. And full gears for Lakes or Peak where the hills are long and draggy.
Posted : 09/02/2010 10:29 pm
 DT78
32x18 for afan for me, and that was hardwork (unfit)
36x16 for local flatish woods
Posted : 09/02/2010 11:08 pm
