First attempt at tu...
[Closed] First attempt at tubeless and.....
[#4969046]
It worked!
Mavic 719 with Specialised the captain tyre.
I used electrical tape as rim tape then a rim strip.
Bit of washing up liquid round the bead and went crazy on the track pump and it went up a treat.
Really surprised as a lot of people said I would need a compressor. Track pump is a cheap nasty jobbie that I payed £3 for so even more impressed.
So for those that think it's a faff, it's not.
Let's just hope the front one is as easy.
Posted : 17/03/2013 9:51 am
Hmmmmm, good luck with electrical tape AND sealant... If you do get problems the Stan's tape, although expensive, is fit and forget.
Enjoy, tubeless gives such an improvement on trail feel.
Posted : 17/03/2013 9:55 am
I made the mistake of saying the front was easy so the back will be too. It wasn't.Took a near-record breaking number of uses of the F word in one sentence. That was using Nic Evo Snakeskin TL ready on DT EX500s using Stans tape and sealant. Went up first go on the front with a trackpump. Rear took an fifteen minutes of shouting and swearing.
Posted : 17/03/2013 9:56 am
Same rim stans tape and an ardent exo first time though it dropped pressure after a week of hard riding would have been fine but bent the f'in presta thing...
Posted : 17/03/2013 9:59 am
I'm considering going tubeless, what happens if you get say a thorn puncture? Do you just keep cycling & you won't realise or does it require you to pump it up a bit?
Posted : 17/03/2013 10:26 am
Depends. I've picked up thorns without realising, sometimes it hisses for half a dozen revolutions then seals. Last week I had to add air before it sealed. All are preferable to replacing a tube on a cold night when your bike is covered in mud!
Posted : 17/03/2013 10:31 am
What issues are there with electrical tape and sealant?
I do have the Joe's no flats tubeless kit so have some proper rim tape to use if necessary.
Just thought I'd give electrical tape a go to see if it worked.
If it makes any difference I have done 1 run round the rim with duck tape as well.
Posted : 17/03/2013 10:44 am
I thought that when I had my first attempt, tyre up holding pressure, hit the trails, took a not massive drop at stainburn, BAMM! blew the tyre clean off, not wilding keep to try again, I was ever so upset.
Posted : 17/03/2013 10:45 am
Insulation tape is fine or Gorilla tape for that matter - you just need to make sure rim is grease free and everything is room temp to get a good bond from the tape. Have used insulation tape with Stans fluid for over a year with no problems.
Posted : 17/03/2013 10:49 am
Superstar do some yellow rim tape that looks like stans but is a quarter of the price. Insulation tape seems OK though.
Posted : 17/03/2013 11:17 am
Wondering if I really needed the rim strips. Pretty sure the duck tape and insulation tape will have sealed the rim.
With that in mind can you just buy a schrader valve that locks down on to the rim?
Posted : 17/03/2013 11:25 am
