Finally changing...
[Closed] Finally changing...
[#4851234]
The bearings on my Pitch this weekend but without specialist tools.
Well i be right or is the task doomed from the start?
Posted : 08/02/2013 9:10 pm
Horst link (where chain stays and seat stays meet) is tricky if you can't pull em out
Angles on the stays make it difficult to put em back In straight
The rest of them are pretty straightforward - if you don't need to change the Horst ones don't bother
Posted : 08/02/2013 9:35 pm
Ah cheers for that.
The set nearest the bb are the knackered ones so will leave the horst ones in that case.
Posted : 08/02/2013 9:53 pm
let me know how you get on mine are about due too
Posted : 08/02/2013 9:56 pm
You'll have the report on your desk Monday 8)
Posted : 08/02/2013 9:59 pm
Thank you kindly 😉
Posted : 08/02/2013 10:01 pm
When you're reassembling shock pivot, stick a large Allen key thru to hold it together
Check the manual to work out what washer goes where and build it up around the Allen key
Then put bolt back in from the other side
It's a bit of a faff (I'd describe it more accurately but already been criticised for swearing this week)
Posted : 08/02/2013 11:59 pm
