Filing down brake p...
[Closed] Filing down brake pads
[#4066369]
Is it possible to decomtaminate a brake pad by filing down using a fine sandpaper?
and is it safe? I heard some brakepads are made of asbestos? Mine are basic shimano jobs, no idea what they are made of.
Posted : 13/06/2012 11:04 pm
Old car brake pads used to be with asbestos in them, I can't imagine modern bike pads have any in them.
It maybe that the contamination has seeped in too far. I have sanded pads down to get rid of the glaze on them before.
Posted : 13/06/2012 11:18 pm
Sanding down pads is a pretty common way to try and remove glaze/contamination/squeal. You'll be fine unless you actually eat the brake pad shavings.
Posted : 13/06/2012 11:33 pm
Stick them in the dishwasher, there's nothing better for degreasing components.
Posted : 14/06/2012 8:38 am
put them in a vice, hold a lighter underneath until they start to smoke, then clean up with sandpaper*.
At least in my case, the oil had soaked into the pads and sanding alone did nothing, after this they were perfect again.
(these were organic superstar pads, still in use 6 months later)
*NOTE: MAKE SURE TO USE PLIERS TO PICK THEM UP. I STILL HAVE A A MISSING BIT OF THUMBPRINT FROM WHEN I FORGOT THIS
Posted : 14/06/2012 9:07 am
Are these the pads at are £5 a set?
Posted : 14/06/2012 9:10 am
blow torch till smoking - quench in water
repeat 3 times.
Sand
Done.
Posted : 14/06/2012 9:25 am
Put a blob of swarfega on one of the pads then rub them together. Worked for me.
Posted : 14/06/2012 9:30 am
Do you really go to these lengths to try and rescue brake pads?! Personally I'd rather not risk imminent death* for the sake of a few quid.
*possibly
Posted : 14/06/2012 9:36 am
When they are so expensive and can be saved in 5 minutes. why not? You forget the disc is also contaminated so you have to decontaminate both. Why risk brand new pads?
Posted : 14/06/2012 9:41 am
Just make sure you use Brake or Carb cleaner,Meths !,NOT,petrol,turps on any oily substance,its gotta be something that evaporates.. !
Posted : 14/06/2012 9:46 am
brake/carb cleaner is designed for a car not a bike. Some of these contains various oily substances which **** your brake pads. BURN THEM TRUST ME ITS BETTER!
Posted : 14/06/2012 9:49 am
Fair point about the discs, hadn't thought of that. But as I have not(yet) contaminated pads/discs it seems weird to set fire to parts!
Posted : 14/06/2012 9:53 am
