Few hours in Dalby ...
[Closed] Few hours in Dalby forest
 rhid
[#10285932]
I will be passing through the area next weekend and was hoping to get a ride in. Realistically I just want about 2 hours or 20km riding so what are the options?
A quick Google suggests that the red is 34km so that probably is out. Is there anything else I could do that's worth doing?
Posted : 20/10/2018 6:13 pm
You don't have to do the whole red. Get the trail map and chop off the furthest sections using fire road
Posted : 20/10/2018 6:19 pm
You can do the red in about 2hrs 30 if you go for it. Well I can, others can do it much quicker.
If you download the trail map it's pretty straightforward to follow the red to Dixons Hollow then follow the road for a bit to cut off about a third.
There are other options but that's probably easiest, and should be a couple of hours.
Posted : 20/10/2018 8:08 pm
Is the black route still there? It's not marked on FC map.
Posted : 21/10/2018 10:21 am
There's the black WC route around Dixons, and a few little diversions off the red.
Posted : 21/10/2018 10:56 am
