My 2007 Marzocchi MX Comp has started bottoming out very easily, if i push down on the bars it'll bottom out.
Any ideas as to what's happened to it?
Posted : 02/03/2012 10:57 pm
Lost air pressure or spring gone.
Posted : 02/03/2012 11:22 pm
Check air valve assembly (valve cores might be loose or replace - same as schreader tube). Test with water around valve. Replace/check o-rings on caps. That prob solve it, as had a similar problem with 2005 mx comps
Posted : 03/03/2012 12:05 am
Good stuff, thanks for responding
Posted : 03/03/2012 12:07 am
My m8's set progressively leak over several months, try just topping up the air...
Posted : 03/03/2012 12:22 am
