Faulty Brake Advice...
[Closed] Faulty Brake Advice Please
[#3974773]
Despite having my rear brake recently serviced by my lbs they are still seem to be losing pressure if left. I have to constantly pump the lever to get it to work.
Even when they work it's not brilliant.
The brakes are Shimano XT approx 4 years old.
Any suggestions on how I can remedy the problem
Posted : 14/05/2012 8:42 pm
 jonk
Take the pads out, can you see any fluid weeping at the seals of the pistons.
Posted : 14/05/2012 8:43 pm
Just checked couldn't see any fluid
Posted : 14/05/2012 9:08 pm
What about the reservoir on the lever? I assume there's no oil weeping out or you'd see it, but take the cap off and see if the rubber seal/bladder is damaged or split. Make sure you rotate the lever horizontal before you take the cap off.
Posted : 14/05/2012 9:12 pm
doubled checked bone dry
Posted : 14/05/2012 9:15 pm
I'll try looking at the resevoir tomorrow. Can you get a new seal?
Posted : 14/05/2012 9:16 pm
Don't know sorry. Probably, try the LBS you had it serviced at, (and it is damaged you can have a mild complain at the same time!)
Posted : 14/05/2012 9:26 pm
