Fatbike forks - DIY...
[Closed] Fatbike forks - DIY - no welding - from junk.
[#1908481]
[u][b][url= http://forums.mtbr.com/showthread.php?p=7231805#post7231805 ]If you fancy building yourself a free fork for your fatbike, look here[/url][/b][/u]
A simple rigid fork with variable ride height and offset.
[url=[url= http://farm5.static.flickr.com/4096/4904616615_cbfa2e2e34_z.jp g" target="_blank">http://farm5.static.flickr.com/4096/4904616615_cbfa2e2e34_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/34903211@N02/4904616615/ ]Completed fork 3[/url] by [url= http://www.flickr.com/people/34903211@N02/ ]epicyclo[/url], on Flickr
][/url]
The lowers are from a junk Zoom fork - couldn't get much lower than that 🙂
Posted : 18/08/2010 7:41 pm
 LoCo
Quality bodgery there, well done!
Posted : 18/08/2010 7:52 pm
hats off to you man.
most excellent
tell us if they hold up ok
Posted : 18/08/2010 7:58 pm
Bump>slip>lock>weeeeeee>ouch!
Good luck tho!!
Posted : 18/08/2010 8:01 pm
Thought of that.
Can't slip down, the stanchions are resting against solid spacers at the bottom of the lowers.
In any case I'm using seat clamps, and they can hold a seat under impact. There's one each side so the forces are approx half what the seatpost gets.
Posted : 18/08/2010 8:21 pm
do video your rides.
Posted : 18/08/2010 8:26 pm
You realise your wheels are clamped in with less surface area and tension than these forks have on their clamps, don't you?
I will report and show pics of my toothless state if they fail though 🙂
Posted : 18/08/2010 8:44 pm
WTF relevance is that?
Posted : 18/08/2010 8:50 pm
I thought you were being cynic-al about the fork holding together. Sorry.
Posted : 18/08/2010 8:53 pm
I'm sure everything will be fine then!
Posted : 18/08/2010 8:56 pm
easy done eh?, nice bit of home brew bodgery there :mrgreen:
Posted : 18/08/2010 9:01 pm
lawyer in engineering mode again
personally i think those will be fine brian 😉
i like it - i might get in on that action shortly 😀
rather the narrow rim for larry though no ? loving the look of speedway cycles rims my self 😀
Posted : 18/08/2010 9:04 pm
Surely you will die 😯
Posted : 18/08/2010 9:08 pm
The rim is temporary. It's a wheel I built up for a 1,000 km overland in Oz 9 years ago and was the fattest rim I could get at the time (40mm).
Got a set of 100s on the way, although I suspect around 80 is the optimum.
Wait until you see the bodge I have dreamt up to make a fatbike frame 🙂
In the meantime, I'll stick this on the Scandal.
http://russellworthington.blogspot.com/2009/03/10-deserts-solo-cycle-epic.html
Some reading for you! 😉
Posted : 18/08/2010 10:30 pm
 DT78
Nice handy work. Must admit this is the first time I've heard of a 'fat bike' - is this just another niche thingy? Big draggy tyre in front? What are the advantages?
Posted : 18/08/2010 10:37 pm
May well hold up fine...as I said on another thread I'd be concerned about the forces on the bottom of the sliders. I was just poking fun at your stats above and their relevance.
Posted : 18/08/2010 10:42 pm
myheadsashed - Member
Thanks. I've been over a lot of the eastern end of his route. I lived there.
It's hard to stay alive in that country. No matter how well you plan it, luck plays a large part in your chances of survival. (Unless you are followed by a 4wd support, in which case it's just another plastic adventure)
Quite an epic.
Posted : 18/08/2010 11:54 pm
Brave!
Posted : 19/08/2010 8:31 am
 Tim
What crown are you using?
Posted : 19/08/2010 11:04 am
