fatbike advise
[Closed] fatbike advise
[#9329752]
hi guys sorry if this has been talked about before but after this weekends ride i am getting a pain / tingling in the hands while riding my on one fatty trail . i am using ogi yeti grips which i have used on all my bikes ( although none have been fattys ) could the vibration from the oversize tyres be a part of it and what type of grips would you recommend if we think it may be grips .
everything else is rally comfy its just the hands . it feels like i have been holding something for a long time and hands are getting really tired
Posted : 15/05/2017 9:37 pm
front suss or rigid?
Posted : 15/05/2017 9:42 pm
What tyre pressure you running?
Posted : 15/05/2017 9:44 pm
What oink said. If rigid, I bet the undamped 'suspension' from the tyre plays a big part.
Surely any suspension would lessen vibration?
Try dropping your tyre pressures a bit. 9-10 psi should be plenty for general trail use. Also try moving your saddle forward a touch so you have less weight resting through your wrists to the bars - you'll be sitting a bit more upright (assuming you've already got a fairly short stem). And finally, relax your grip a bit! Hope that helps
Posted : 15/05/2017 9:50 pm
Blutos up front running 9psi guys
Posted : 15/05/2017 9:51 pm
Maybe the front end is just too low, putting too much weight on your hands?
Posted : 15/05/2017 9:54 pm
As above, but try moving the bars back towards you a few degrees, your hands should fall onto the grips without undue pressure between the thumb and forefinger,also move the brake levers into the grip a little can help too. hth
Posted : 15/05/2017 9:59 pm
I have foam grips on mine....lovely
Posted : 15/05/2017 10:06 pm
Not if it springs back at the same speed, or faster, as it was compressed, due to a lack of rebound damping
Posted : 15/05/2017 10:07 pm
Try rotating bars/shifter/brake positions for a start 🙂
Posted : 15/05/2017 11:24 pm
Higher rise stem for me, 70mm x 25deg. Gets some weight off the hands.
Posted : 15/05/2017 11:29 pm
tilting the nose of your saddle up a little might help too
Posted : 16/05/2017 1:48 am
I've got the same bike ,running 8/9 psi in the front with carbon bars and esi extra chunky grips . Bars and saddle are level .
Posted : 16/05/2017 6:30 am
May not be a component issue..... More likely to be positioning or you could try loosening your grip?
Posted : 16/05/2017 8:44 am
