Fat Hubs alternativ...
[Closed] Fat Hubs alternative to Surly?
[#3978655]
I'm building up some "light" fat wheels for my Pug.
What's a lighter alternative to Surly. I'll need 135mm SS disc rear and a 135mm disc front, both offset..........
Posted : 15/05/2012 8:18 pm
Hope do a front hub that'll fit a pug/salsa/ 10x135 fork.
Posted : 15/05/2012 8:26 pm
Nice, but they don't do a rear SS hub that matches, do they?
Posted : 15/05/2012 8:37 pm
I got some silly light trials hubs from Tarty Bikes.
They do a 135 trails/ss hub that'll fit and match.
Posted : 15/05/2012 8:51 pm
Shaggy, I can't find them, who makes them? Or link?
Stu, sounds worth looking at......
Posted : 15/05/2012 9:16 pm
The new hope evo come in 135mm front which has the right disc spacing for the pugsly fork. A standard hope SS rear hub should work in the back (if you dont want gears?). The front will be slightly light than a surly, the rear hope will almost certainly weigh more.
You dont get offset hubs, thats the rims.
Posted : 15/05/2012 9:29 pm
 Rik
Look at tarty bikes
Posted : 15/05/2012 9:40 pm
The one I have is an Echo disk hub, which I can't see on the site any more. There are a few here though. http://www.tartybikes.co.uk/135mm_fixed_hubs/c21.html
You need 2 rears, not a front and a rear, if you are still running the pug fork.
Posted : 15/05/2012 9:49 pm
Pete, maybe not the lightest but pretty light are Hopes pro 2 rear on the back, and a Pro 2 trial/SS rear up front is a bombproof combo for an offset pug wheelset.
Waiting on a set of Marge Lites to arrive for another wheelbuild with those hubs...
All Hope spares are available and their beach/salt water tested for reliability, 😉
Posted : 15/05/2012 9:51 pm
Thanks chaps.
Shaggy, are you running the fixed hub with a screw on freewheel?
Strato, cheers
coastkid, Ta. I too have Marge Lites...........
Posted : 16/05/2012 7:12 am
Shaggy these?
http://www.ecrater.co.uk/p/9884928/echo-sl-hub-rear-135mm
Posted : 16/05/2012 7:21 am
Similar. Mine takes a screw on freewheel and doesn't have all those holes drilled in it.
Posted : 17/05/2012 7:01 pm
http://www.tartybikes.co.uk/135mm_fixed_hubs/because_rear_disc/c21p11318.html
Tarty bikes don't do the ones you have but suggested these as an alternative.
Hwe's building the wheels, so I'll run them by him....
Posted : 17/05/2012 7:12 pm
